Trouble with US 41 engine
If you are using one of the older fuel tank conversions with the small black line replace the tank line. These lines can kink and cause problems. Use tygon tubing of the appropriate size. Also check for air in the fuel line after the engine quits to see if there may be a hole in the tank line.
