RCU Forums - View Single Post - Best & Lightest Control Horns To Use In 2 Meter Pattern
Old 12-09-2002 | 09:21 PM
Troy Newman
Default MK Bellcrank inside the fuse
#1 the linkage needs to be strong. Also needs to be maitencance free as you won't want to take it out and look at it every week. If I used a MK unit I would use the Central Hobbies 3/16" CF pushrod with a 4-40 Titanium fitting...Then use the MK MKD0891 BB rod adjuster 2.5mm
This BB rod adjuster is a Ball link type device...I would lock tight the nut and screw securing the link to the MK center horn and use that.
Dave Brown arrow shafts will flex cause the 4-40 rods to weaken and fail. This is the place for a CF titanium fitting above all other places....Many people have lost planes not installing this MK device properly or using it properly.
It works very well and is a good product...but has to be used properly. I don't like cables but many people think that switching the MK to cable control inside the fuse is the way to go...
I have a better solution that is lighter and much more positive than the MK...It takes about 3 times the work to build and install. Its not really any cheaper but I feel its a better design.
The MK is probably next on my list of choices... It super simple to install has a bit of a $ tag but is defiantly superior in all other ways to the Dave Brown Arrow shaft. Just because they are black don't mean they are CF...they are fiberglass and flex a ton.....You need a good support system to keep them from moving.....
This is my opinion and other have theirs also....but it is worth exactly what you paid for it.....the advice that is!...LOL
Troy Newman
