RCU Forums - View Single Post - *25cc Conversion & Plane Combo*
Old 03-13-2006 | 04:00 PM
tim220225's Avatar
tim220225
Default RE: *25cc Conversion & Plane Combo*
If for no other reason but weight. The Seagull Edge would not have worked with the Echo 21 on magneto ignition. The whole setup for CH including the unit battery and switch weighs about half what the stock ignition weighs. Some of the shorter nose planes need the weight of the standard ignition. There is no real performance benefit either way. Mine ran about 300 RPM more on CH.
