RCU Forums - View Single Post - Best & Lightest Control Horns To Use In 2 Meter Pattern
Old 02-16-2003 | 09:38 AM
hobdean
Default Re: Rods
Originally posted by YNOT
I really like the MK Alum. Horns. At about 3.5 grams each, weight is not an issue. Strong and look really good.
On my Diablo 2000, which is almost ready, I used some of the 2-56 carbon fiber rods from Central with the HD 2-56 ball joints on the servos and the surfaces. For the elevators, I used the Hanger 9, titanium rods. They are heavier, however I needed the weight in the tail. Not that it added much.
I have tried to find the CF control horns here in the US, but with no luck. Ansano makes some, but Quique doesn't import them. ZN Line, makes some too, can't find them either.
what engine are you using on your diablo 2000?
is this a good plane for pattern and 3d??
want to put a gas engine on it? what size is best? a 3w24? or larger?
