RE: Servo problem
I think you will find Rodney to be on target. Your problem sounds like a power problem not a mechanical problem. I would lean toward a battery rather than a loose connection. What voltage and type pack are you using? There is a good possibility that you are building internal resistance in your battery pack. Try a fresh pack and plug direct into your reciever. I hope you post the answer.
Best Regards...
Mark
