RCU Forums - View Single Post - EDF Airliner build thread
Old 03-13-2006 | 11:14 PM
  #48
EDFmodel's Avatar
EDFmodel
Default RE: EDF Airliner build thread
Serdar
Cheers -
Set the angle of incidence at zero degrees for the stabiliser (that is zero degrees with respect to the carbon chassis).
Assuming you have the rear U/C legs in the same position as the original model, a maximum of 25 mm forward of that position will be a starting point for the C of G. If you have done something else let me know. The realtionship between U/C legs and C of G becomes quite important when discussing ROG. Otherwise such things as models leaping into the air can happen.
Ian
