RCU Forums - View Single Post - prop nut problem
Old 03-14-2006 | 12:34 PM
Campy's Avatar
Campy
Default RE: prop nut problem
Another possibility is to use an aluminum spinner that has the bolt in the center of the spinner (Great Planes and others also). Trim/cut the adapter and/or bolt as needed to fit. The adapter for the spinner will act as the stop nut for the regular nut. I use this setup on my Saito 72 and 82.
