did you take the control rod loose and flex the surface back and forth to full deflection MANY times until the surface is moving "smoothly"? If not DO SO before trying any UN NEEDED braces. braces won't fix the problem If this doesn't help, you'll need to redo the surface attachment. hope this helps
edited to change flew to flex
