RE: mod motors in tc3
As I said above 22/72 is the recommendation from Associated and 23/72 is the result from Skrappy's gear calculator for a TC3 if you are running standard touring car slicks. Also make sure you don't mesh the gears too tight when you install the motor. If it still gets hot try the above things to figure out the source - get back to us if you still have troubles.
