RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 03-15-2006 | 02:25 AM
  #489
aero nut
Default RE: gas fuel with glo plug no ignition
Scott14 you definitely need to choke your carb with your finger or choke lever if possible in order to get priming fuel into the engine, when I did my first conversion it happened to me until I got to think that when you have the engine in your garden equipment you need to prime the engine with a priming bulb or by choking the engine before you start it. Another thing AV8TOR and I are using R/C CAR glow fuel that contains 10% oil in order to get the 3% and the end of the mix, but like AV8TOR mentioned excess oil wouldn't prevent it from firing up, it might drop the RPM'S but it will still FIRE UP.
