RCU Forums - View Single Post - Composite ARF Impact
Old 03-15-2006 | 07:33 AM
  #709
PeterP
Default RE: Impact
I currently have 50+ flights on my Impact without problem. I am impressed and will probably build another. Anyone who has seen my previous posts in this thread will know what extent I went to avoid the failures these models are suffering.
It is easily the best flying model I have ever owned. After a little tweaking and adjust from the intial flights I am happy to report that this model is very true with no trim or mixes. My final settings are somewhat different to their instructions.
DZ160 power is a perfect combo for this model if you plan to use IC. Electric is proven if you have deep pockets.
Make sure you make the changes as suggested in this thread. If you look at my suggestions you should be fine.
Here's a couple of pictures for those that are interested.
Peter
ID:	426422   Click image for larger version
