RE: covering...
rsCVN-71,
I hear that alot about not liking covering. I must be weird or something (Bruce, be quiet. You can't answer that until friday) because I like to cover. Another reason I like using Monokote is that you can use windex to apply trim on top of the base layer. You can also use windex if you are doing Monokote over Ultracote, but you can't use windex to apply Ultracote because it won't work.
Ken
