ORIGINAL: andrew66
i guess its time to cool down and try and figure out how im going to fix this. anyone got any ideas?
If you can't pry them out, try screwing a steel screw into the blind nut from inside the fuselage, then try to tap the nut out of the wood by tapping the head of the screw. You'll want to be sure the fuselage is well supported under the gear block to prevent tearing it off the bottom of the plane.
