RE: McCoy engines
The Fox changed over the yrears and so did the K&B/Veco. Try and put the ringed piston in the ABC cylinder. The needle is now in the back and it used to be in the front. there have been several different Carbs and the parts from a K&B Carb will not work in the Veco carb. Just like the Fox it evolved but it is still the K&B61 and the Fox is still the 35 Stunt
