RE: Beginners FAQ?? We need your help!!!
Ok I havent even flown my trainer yet, but here is some Q's I have had recently.
How do I refuel my plane?
Are Air and Fuel filters necessary/recommended?
What is the difference between Nicad, Nimh and Li-po batteries?
How do I repair tears and holes in the covering?
How do I clean my plane after running it?
What after run oil should I use and whats the best way to apply it to the engine?
For running on grass/pavement whats the best type and size tyre to use?
If I want a three blade prop what size should I use?
How do I adjust the throttle linkage/servo properly?
Whats the best way to charge/discharge my RX/TX battery pack?
What exaclty is Nitro fuel?
Where should I set my throws?
How do I do a range check?
How much toe in do I need on my taildragger front wheels?
How do I prime my engine for starting?
How do I mount servo's/RX etc (can I run the cables together or do they need to be seperate etc?)?
Whats the best way to attach the wing with rubber bands ie: how many do I need and what size?
How do I fix out of round foam tyres?
Whats the best glow plug heat range to use?
How do I apply additional graphics to my plane?
What causes servo twitching?
How can I reduce the risk of interference?
How should I store my plane?
What's a clunk?
How do I setup the clunk in the fuel tank?
What does adding right or down thrust do to the handling of my plane?
What is flutter?
How do I attach my receiver aerial to the plane?
Low wing vs High wing characteristics?
What is dihedral?
How do I repair stripped servo hold down screws?
The covering is wrinkly, how do I fix this?
What do I need for a day of flying (tools, materials, charger, fuel containers and flightbox etc)?
Will my mobile phone interfere with my plane?
Should I use synthetic oil fuel?
How do I attach wheels so they spin freely without being too wobbly?
How do I stop fuel tank foaming?
Some of these may have already have been suggested. These are some questions I needed answers for recently and in the past.
