RCU Forums - View Single Post - Adding weight
Old 03-16-2006 | 03:00 AM
ArCeeFlyer's Avatar
ArCeeFlyer
Default RE: Adding weight
Don't forget to see if there is anything you can reduce at the tail, i.e. lighter tail wheel, mount and axle, anywhere you might be able to add lightening holes (obviously recovering required in those places). It takes a lot less weight change way back on the tail to accomplish an equivalent c.g. shift done with a larger weight change on the nose. Every little bit helps.
