RCU Forums - View Single Post - Pull-Pull woes
Old 03-16-2006 | 08:17 AM
elenasgrumpy
Default RE: Pull-Pull woes
I've only done one pull-pull on the E-Flite Mini Edge 540. The instructions had me run the cables straight part way up the fuse then crossing over thru 2 holes in a former to create the correct geometry for it to function properly. Once I had everything lined up & pulled the wires snugly tight it worked like a charm.
