ORIGINAL: rajeev
Thanks for the quick replies, guys !
Chuck, I'll check up all you said and will get back here.
Wxman, the wires are quite tight but not as in a bow string. I mean, if i pull the wire with my finger about four inches from the rudder control horn, it displaces for about half an inch.
Rajeev
I don't think I have that much play in mine. I also had to check the tension was the same on both sides as well.
