RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-16-2006 | 02:53 PM
  #2589
GTX SlotCar's Avatar
GTX SlotCar
Default RE: E-FLIGHT BLADE CP
ORIGINAL: ronaldpa
I am having trouble with my blade . When I plug in the battery with the transmitter on it does not go active it keep moving all its servos and them stops . I turned of my remote and it went crazy. WHat can it be ?
Here's what I'd try.
Check to make sure the throttle and throttle trim are set to 0, all the way down. Then turn everything on. If that doesn't work, try re-seating the crystals. If that doesn't work, check you battery voltage in the transmitter. If that doesn't work, go to the link ILO64 gave.
