ORIGINAL: GTX SlotCar
ORIGINAL: ronaldpa
I am having trouble with my blade . When I plug in the battery with the transmitter on it does not go active it keep moving all its servos and them stops . I turned of my remote and it went crazy. WHat can it be ?
Here's what I'd try.
Check to make sure the throttle and throttle trim are set to 0, all the way down. Then turn everything on. If that doesn't work, try re-seating the crystals. If that doesn't work, check you battery voltage in the transmitter. If that doesn't work, go to the link ILO64 gave.
And make sure the idle-up switch is switched towards the rear of the transmitter.
