ORIGINAL: hillric
I am new to the world of RC Airplanes. I have been using Omega 10% Caster/Synethitic Fuel and on the label it reads DO NOT USE AFTER RUN OILS! However, I have been told be friends that I should use AFTER RUN OIL. Which is right. I want to protect the engine from rust can corrosion.
Rick
As stated in the thread, make sure you run the engine dry. Morgan fuels allege that they have inhibitors in their fuels. My take is to run her dry and them pump some after run oil into the intake. Then turn over the engine with your starter to spread it all around.
I use Rislone and ATF 50/50 mix as an after run oil.
Cheers,
Chip
