RCU Forums - View Single Post - Need 2006 Basic
Old 03-16-2006 | 05:06 PM
ICE_MAN's Avatar
ICE_MAN
Default RE: Need 2006 Basic
Hey guys,
Thanks for the help.
ki0qm ,
How do you do a reverse sharks tooth. If I remember correctly, a regular sharks tooth, from the 2005 sequence: pull to vertical, then at the top pull to 45 degree downline with 1/2 roll on the way down, then exit straight & level?
If that's the case then the reverse would be: pull to 45 degree upline, half roll to inverted, pull to vertical downline, pull to exit..
Correct?
EDIT: Watched the cirkus vid. after posting Nevermind
