RE: Beginners FAQ?? We need your help!!!
Since you asked, the best way to remove epoxy is with alcohol or acetone, before it cures. After, it will eventually peel off your fingers. For the plane, use a little heat to soften it, but not so much that you melt the covering, and then you can usually peel it off.
