ORIGINAL: F2G-1
A forwarg CG will not only cause a higher AOA, it will also increase the wing loading.
Ted
How is this possible? ----Either area you've touched on.
Without an increase (or decrease) in overall weight of the A/C wing loading is unchanged. CG has nothing to do with the loading calculations.
If you have an explanation I'll be more than happy to consider it.
