RCU Forums - View Single Post - Pull-Pull woes
Old 03-16-2006 | 10:04 PM
forestroke's Avatar
forestroke
Default RE: Pull-Pull woes
is it forward or rearward for ackerman? i remember it to be rearward.
it's important that your rudder servo horn is absolutely perpendicular to the fuse when your rudder is at neutral, if you're using trim to get to neutral, then you're bound to have some issues.
good luck!
