RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-17-2006 | 09:43 AM
  #2599
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: RamboSmurf
Again, Thanks for the help. Upon further review. It appears that I have a GWS Picco std servo on the left rear. E-Flite on the other 2. The GWS is working backward. Anybody have a Functional Heli Gunship, because I want to strafe the previous owners house. Would a Esky Honeybee servo work until I get the correct one from E-Flite. Again, Thanks to all.
RS
The GWS will work fine. All you have to do is reverse the switch on the TX on channel six. Also make sure the signal wire is to the inside of the RX.
Dennis, did you get e-flite servos? I don't have any play in any of mine. Maybe you got a bad batch.
