RE: need help bad......
an engine should always be adjusted slightly rich no matter how new or old it is. you lean it to get good top end performance, then back it off a little like that tuning guide said. running an engine at its peak mixture adjustment can be dangerous because mixture changes with different weather conditions and that could cause an over lean setting, so its best to always run it a little on the rich side.
