RCU Forums - View Single Post - P-47D eflight
Old 03-17-2006 | 03:14 PM
  #31
stoneenforcer
My Feedback: (23)
Default RE: P-47D eflight
ORIGINAL: jrobert59
One tip I have is to pin the cowling on rather than use the double sided tape. I just used 3 straight pins placed around the cowling and it's solid and easy to remove now.
GREAT tip! I will have to try that! I have a replacement cowling, wing, and elevator coming due to my aforementioned wear-and-tear (non-crash) damage.
I wanted to ask what prop you are using and what is your auw?
I don't have the machine in front of me, but I seem to recall that mine was 26oz. Every ounce counts on this bird, so I went with HS-55 servos all aro
und, took the casing off my Hitec Supreme receiver to shave a few grams, etc. I use the stock prop and a Master Airscrew 10x8E Electric Only prop.
I want to try an 11x7 or 11x6 as well; the P-47 flies a bit faster than I'd like (I like scale speeds) at full throttle, and I'd like to go with a bit more thrust than speed due to my elevation (5000 feet).
I don't feel I'm getting the performance that others have stated and I'm not sure why. I've been using the E-flite 10X8E prop and the TP 2100mah batteries and the Park 450. I can't vertical climb without nosing over and it just seems sluggish. I did have to add 2.5 oz of lead in the nose and my auw is 28 oz.
The factory-listed CG is slightly ahead of where I think it should be. Nose-heaviness will hurt your upline significantly. What you want to do to figure this out is go full-throttle and point your bird at a 45-degree angle. Watch what it does. It should SLOWLY nose-down to horizontal from a 45 if it's balanced correctly. If it noses down quickly, you've probably got a nose-heavy CG. If the tail swings forward and it wants to climb vertically, you're probably tail-heavy.
Note that thrust angles can cause the same behavior, so if possible try this with varying throttle levels. You'll figure it out.
IMHO, you won't get "vertical" performance on a Park 450 with the stock prop unless you live at sea level (maybe; not even sure on that). It will hold a solid 45 degree climb on the 450 and a TP2100 3S1P LiPo. I fly with a heavier Master Airscrew 10x8E "Electric Only" prop most times. It's slightly more "thrusty" with a lower top speed than the E-flite 10x8E. Because the prop is so big, even the slightest imbalance is exaggerated and will rob power.
Compared to a 3D flyer, like my ParkZone Typhoon, the P-47 IS sluggish! It has tiny ailerons (comparatively), and a far worse thrust-to-weight. One thing I've noticed is that the Park 450 can really build up a head of steam. It goes fast if you just keep it level at full throttle. I'm thinking of going up to a 12x6 or a 11x7 prop to try to get more thrust and less speed. The 12x6 may be a problem with the stock landing gear, but I think an 11x7 or 11x7 will fit just fine.
I've balanced my props but I do notice a vibration with the prop at about half throttle. I'm trying to think what other power leaks I might be overlooking. Any feedback will be appreciated.
Be very careful with that vibration. As mentioned, the shaft mount for the P-47 is only hot-glued in by default, and tends to become really wobbly. Try running your motor with the prop off, and lightly press a finger against the naked shaft with the motor running at the usual "bad vibration" point. Can you feel a little vibration with your finger? You may have bent the prop shaft on you 450, and this will rob a lot of power and suck down more amps.
The 450's aluminum shaft is quite soft. One good nose-over, like the one my buddy did in the grass, can bend it enough to cause serious power problems. Put a new shaft on order with your LHS as a spare, regardless. They're only 4 bucks. Once I get my replacement in, I'm going to try straightening my old one using the c-clamp method.
ORIGINAL: sjchmura
Since you have to move the wieght forward is the $10 more for the eflight 480 worth it? Does the 450 and 480 give good verticle performance?
The 450 will zip the P-47 around the field at a very nice clip and enable beautiful faster-than-scale aerobatics with very large loops. But with the stock prop, it is by no means a vertical performer. You'll need to upgrade props to get vertical out of it. I'm guessing a 12x5 or 12x6 will almost certainly do it, but I'm going to try an 11x7 first since I run with gear. If I were landing gearless in grass, I'd probably go straight to a 12-inch prop.
I'm not sure on the 480, as I don't have one, but I hear that the amp draw goes up precipitously with the stock prop. I'm trying to find the thread where someone tried the 10x8E on the 480, and the runtime was really low.
Flying in small spaces and being able to "pull up and gun it" can really save the bird
The Park 450 enables a solid 45 degree climb from minimal speed. A light toss at full throttle works great for a launch. However, trying to gun it straight up on this motor is a recipe for disappointment
How does it fly landing on grass WITHOUT the landing gear? I usually fly in parks so no place to land but longer grass.
It flies much better without the gear. I'd recommend packing tape (or fiberglassing) just behind the wing set screw on the wing support panel to preserve the finish, and the same treatment for the wing leading edge through past the fake landing lights on the wings. If the grass is long-ish, it will tear up the leading edge and the area of wing just outside the ailerons. The foam is very thin there.
Remember that packing tape is a PERMANENT improvement on this bird. If you try to pull it off, man, does it ever get ugly fast. I have a new wing on order for this reason, due to my attempts to keep the wing panels from pulling out in flight over and over and over again despite the secure double-sided tape jobs I've done. That foam is just slippery, I guess.
That said, the P-47 coasts in nicely to an easy flare-and-flop landing without gear. You can't maintain a "high alpha" approach like the Stryker, but it works. Word of warning, though: Don't try to do flaperons using those little ailerons a the tips. They just make you tip-stall.
For landing in grass, I make my turn to final rather high. I gauge my distance, and usually nose it down a lot and dead-stick it. If I need to extend my glide path, I throttle up some. I can usually just flop it at my feet now, and it skids for a total of maybe three to six inches. Long grass and weeds, however, tear it up something awful. I don't recommend landing in tall, dry weeds.
How is the slow speed landing compared to the Stryker? The PZ P51 is kinda FAST on landing (stable but you NEED TO KEEP UP THE SPEED)
It depends on your build. With the full-house build including landing gear, approaches must be rather quick, and comparable to the landings I've seen on the PZ P-51. With just aileron and elevator controls, no landing gear, and a LiPo lighter than the 2100mAh, it's a real floater and coasts in much slower.
The E-flite P-47, like its full-scale counterpart, is a "nicer" flyer than the P-51. It flies slower and is less aerobatic, but it's much more forgiving. If you bring it in too slowly, it doesn't tend to tip stall, but instead the nose just mushes down. Like most low-wing warbirds, though, you really want to keep your speed up. I dead-stick land it most times, but that's only because I'm used to aggressive, high-speed dead-stick landings. The sink rate on most warbirds sans power is alarming the first few times!
Suffice to say, it doesn't float in nearly like a Stryker at high alpha. But it's very controllable; if you've landed a Stryker, just remember to keep this one going a little faster to land it.
In the stock configuration, with gear, you have to be very careful of your approach vector, though. Once the tailwheel is planted you have zero control over direction of the plane other than very very slight rudder (at speed; once you slow down, that's gone too) and throttle to touch-and-go. This is why I usually recommend a "wheels landing" if using gear on the P-47 and landing on asphalt, in order to keep that tailwheel off the tarmac as long as possible; if you're going to land on grass, then I recommend a hand-launch and a slow "flare and flop" landing.
Also would the BP21 work instead of the 450 outrunner???
KVs (RPMS per volt) are WAY too high on the BP-21. The Park 450 is an 890Kv motor, rated for 12A at 11.1V. The BP-21 is 1750Kv, rated for max 13.1A @ 11.1V. I strongly suspect you'd burn it out trying to swing a 10x8E at 11.1V. You need a lower KV, "thrustier" motor. If you geared the BP-21 down 2:1, though, it should work fine.
If it's just that the Park 450 is too expensive, the BP9Y and BP2908-10 outrunners look like they may swing the stock prop well. I know the 2908-10 would do just fine (and have a higher top speed and amp draw than the 450), but the 9Y may be a stretch.
redgiki
Thought for the moment:
As in certain cults it is possible to kill a process if you know its true name.
-- Ken Thompson and Dennis M. Ritchie
[/quote]
