AJF, nope. No afterthought. The rebuild was way too much work for me to consider it an afterthought
This plane had over 300 flights on it and the entire front from mid-wing forward was badly oilsoaked because of how the Saito exhaust was directed. I replaced everything forward of that point with new wood. Replaced the ABS filler piece in the tailfeathers with builtup wood. I should be able to get all the vertical jollies I can handle with the CAP.
The Stinger will be a Sunday driver.
Here's the CAP. My color scheme looks a "little" bit different than the stock yellow Breitling scheme. It's my first large covering job. Metallic purple, white, flourescent lime green Ultracote.
http://pwp.starnetwx.net/leckert/
