RCU Forums - View Single Post - Does the Edge like to pitch to the belly on vertical uplines?
Old 12-09-2002 | 12:06 AM
mecam's Avatar
mecam
Default Does the Edge like to pitch to the belly on vertical uplines?
Originally posted by Diablo
A pitch to the belly in uplines can also be from too tailheavy. You should check the difference between uplines (power on) and downlines (power off). If it pitches to the belly in both, it's a weight balance issue (tailheavy).
Hmmm, you know I notice the pitch more after I moved the CG back 3/4". Maybe that is it. By the way the Edge is a H9 and planning to use it for IMAC Sportsman. I should move the CG forward for IMAC.
