RE: Official HPI Hellfire Thread
quote]i have 3/4 gallon through mine and lots of power but still problem with the dying after a hspass or jumping. i called hpi and they said that the lsn and msn might need adjusting. i am at a loss for now. i was messing with yesterday but i still havent figured it out. i am getting really irritated with it.i wonder if its possible if theres a leak on the carb?[[/quote]
What's happening here is a tuning issue. You need to spend some time after the engine is warmed up and tune the engine. Your needle settings are off. A leaking carb will in most cases cause your engine to run overly hot.
A good thing to do is to seal your engine to enable you to rule out air leaks from any tuning issue you may run into.
