Using an incidence meter
Incidence is the angle of the wing in relation to the fuse. Take the CENTERLINE of the fuse and set it to 0*. Then you have to find the CENTERLINE of the wing, some incidence meters do this for you, and set the wing to the desired angle. Obviously this is the simplified version, but you should be able to figure it out. There are many good incidence meters. I use the one from Great Planes.
