RE: Phoenix Tucano maybe?
What Sigrun says its true, the Tucano has a more tapered wing than the PC9. As he says maybe another low wing plane would be betetr (like the WM T34, WM Sky Raider Mach II, Sig 4*, Phoenix Scanner etc). Like I said, unless you are really good on your trainer, meaning, you tell the plane what to do and not otherwise ... then perhaps you can handle the Tucano.
