RCU Forums - View Single Post - Range Check Problems
Old 12-08-2002 | 03:38 AM
rcairpilot
My Feedback: (22)
Default Range Check Problems
Hi there,
I have two planes now with range problems. My transmitter is an 8UAFS. I purchased a Sig Cap 231 a year ago. It has 9202 servos except for throttle. I am running the R128DF receiver on channel 58. I installed a gas engine on it. I was unable to more than 50 feet out of it with the engine off. I was told that my servos were causing the problem as they were a little jumpy around neutral. They are at Futaba now getting the pots changed on them. I was hopeful that this would fix the problem, but now I am not sure as I have another plane that is acting exactly the same as that one. It is setup similarly, with split elevator servos. I just went out to the field today for my first flight on my Ohio R/C Pepsi Chipmunk, 81" wingspan. R127DF receiver on channel 42. I was doing the original range check on it and found that I could not get more than about 40 feet away with the engine off. The guy that I purchased the plane from was there helping me. We tried everything imaginable. Moving the antenna several times, changing receiver and battery, and unplugging the different servos to see if they were the culprit. They are Tower Hobbies servos. The only thing that gave me any range was him holding the plane with the wing off, and the antenna wire hanging straight down. As soon as the antenna was moved toward the rear of the plane, servos started jumping. The reason that I am so frusted with this plane now is that I bought the plane with everything installed except receiver and battery. He has flown it more than 100 times with his JR equipment in it. It should have worked just fine with my receiver. The other receiver and battery that I used in my test came out of my Uproar that I ended up flying today as I could not get this problem figured out. It range checked fine with no problems. The only real similar things on the two problem planes are, pull-pull rudder cables and use of the lower end receivers. The Chipmunk has elevator servos mounted under wing. You posted a reply to one of these questions, stating that the R127DF is more sensitive to interference than other receivers. Is that my whole problem? Do I need to get better receivers? If so, what is a good choice without having to spend an arm and a leg. I have 3 of my 127's at Futaba also getting tuned to #58. Can they do anything to them to boost them up or change them? Please reply ASAP and let me know. Thanks
