RCU Forums - View Single Post - Sig Akromaster Wing Weight
Old 03-18-2006 | 06:20 PM
Phlip's Avatar
Phlip
Default RE: Sig Akromaster Wing Weight
[link=http://www.rcuniverse.com/forum/m_2380036/anchors_2380036/mpage_1/key_/anchor/tm.htm#2380036]http://www.rcuniverse.com/forum/m_2380036/anchors_2380036/mpage_1/key_/anchor/tm.htm#2380036[/link]
Check out the above thread for Flite Steak info. I think the general concensus is that the balance point in the instruction book that comes with the FS ARF is considerably too far back. I think the OS .35 is quite a bit more motor than you need, too. I'd try setting it up pretty rich, at first.
Sorry, I can't help you with the Akromaster. Doesn't the plan tell you the tip weight?
Phil
