RE: E-Flight Ultimate FX 3D for RealFlight G3
yeah... if you look at mine you'll see that I did the same. The physics model on mine is as accurate a representation of the real model as I could make it down to the weights of each individual component. On the FX 3D obviously the fuse is full so that part is still full fuse in mine. I also recreated the e-flite motor and a thunderpower lipo for it along with the correct sizes for the control surfaces.
Did you share yours? Cause I've not seen it.
