RCU Forums - View Single Post - TF Spitfire Build (Gold Kit)
Old 03-19-2006 | 11:26 AM
rgrella
Default RE: TF Spitfire Build (Gold Kit)
Here are pitcures of the Fin and Rudder. After looking at the pictures i can see where more sanding and filling is needed. I use my finger touch to find dents and dips and use filler. Any pointers would be welcome, i could use them.
ray
ORIGINAL: rgrella
I'm interested in sanding tips and how to get the contours dead on etc.. I've made a couple of custom sanding blocks and a templete to check the elevator curves. I wish there was more information on how sand and build.
I do refer to the Spit build from the person from Twain. It has been a great help.
ORIGINAL: saramos
Welcome to the world of the TF Spit. I am finally approaching the end of my build, currently adding panel lines and other final details. If you have any questions, don't hesitate to give a shout. I'm sure you've come across it, but I'll go ahead and mention it anyway. Be sure to check out the very informative spitfire build thread by Tubig.
Good luck and great building.
Scott
ID:	428928   Click image for larger version
ID:	428929   Click image for larger version
ID:	428930   Click image for larger version
ID:	428931   Click image for larger version
ID:	428932   Click image for larger version
