RCU Forums - View Single Post - slight anhedral
Old 03-19-2006 | 12:22 PM
jb86
My Feedback: (8)
Default slight anhedral
i am building an edge 47". i built it w/the 2 pc wing conversion, wing built as one pc w/wing socket, then cut in 2 pcs. i thought my building board was flat enough, but when i turned the wing over to sheet the 2nd side, i found a bit of anhedral (opposite of dihedral), about a fat 1/16". with a straight edge across, along the spar from tip to tip, about a fat 1/16". is that bad? i figure being a 3d profile, it will be flying around in every direction anyway, throwing it around in the air.
any input?
jon b
