I was doing my weekly reading on the forums and came across
"Prop nut problem". I know it's a dangerous situation if the nut
isn't installed properly. I'm wondering if I have the right setup
for my Saito 91S on my Dago Red . I have the prop blade reamed
with a prop reamer so that the prop slides on. The first nut that goes
on has a recess in it for the second nut ,which I think might be called the
lock nut and next goes on the adapter for the spinner.I have lots of room
to screw the spinner adapter on. I'm I correct in going with this setup ?
I left the nuts loose so that you can see the recess on the first nut
and split on the middle nut.
