RCU Forums - View Single Post - Q100 strange carb problem
Old 03-19-2006 | 03:17 PM
Aerobat's Avatar
Aerobat
Default RE: Q100 strange carb problem
I took a look at the butterfly, and the screw that holds it to the shaft had come loose. I tightened it up with some red locktite so we'll see if that was the problem.
It's amazing how things come apart on these paint-shaker motors. One time I found that the whole cylinder had come loose from the crankcase. You have to check and locktite everything on a regular basis or it just shakes apart.
Mark
