RE: zAGI 5C
I have a lot off throw in the surfaces. I'm gonna guess at least 3/4" both ways. It may be push rods though, however the other guys have the same rods and they don't seem to be having the frouble that I am with this particular plane.
Here is another one for you that had the guys at the field a little baffeled. I striped a servo on the plane and replaced it with a futaba servo. The Futaba servo would not work with the Hitec receiver and transmitter. The controls were completel oposite what they should be. EXAMPLE:
When you push forward on the stick the plane would actually turn and when you push the stick to the right the plane would climb. I know what you are thinking, this guy has the servos reversed at the receiver...not so, I switched them, same thing. They would not work with the Futaba servo, I hooked a mini Hitec servo to the receiver and it worked fine. What is up with this ?
