RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 03-19-2006 | 08:17 PM
  #1553
LarryQ
Default RE: Vectorflight Edge 540 build
Ahhh...you say Beef up the firewall...
I have the epoxy and cloth..but thought the firewall was plenty srong without reinforcing it!
Have there been problems with the firewalls???
So..If I read this correctly....and since my engine will be side mounted.......
If your looking at the front of the plane....starting at the 2 O'clock position
2 O'clock position (1) 1/8" flat washer + (1) #6 Flat washer.
4 O'clock Position (1) 1/8" flat washer
7 O'clock position No washers
11 O'clock position (1) # 6 flat washer
Is this correct????
Are the washer sizes (thickness) correct??
Larry
