RE: Four-Star 120 build getting started.
man i havent had the time to get on the bandwagon and get working again. Ive decide on a BCMA 33 or 45 cc(same size, only 2 ounces more for the 45) with the electronic ignition package. Motor should weigh in at 2.2 pounds, but will definetly require a cowl(wich i was going to use anyway).
Im still not shure on servos, i need to fix a dent i put in the wing, get the tail feathers built, and make servo mounts etc. thats as far as ill be able to go until i can afford a motor. Covering is going to be fun.....(note SARCASM!!!!!)
