Hello everybody,
I am new to gas engines (I bet you get that a lot
) and I have a question. I have purchased an MVVS 35 gas engine and a Great Planes kill switch. My question is, can I use this kill switch with the electronic ignition my engine has? And if yes, how should it be wired? I was thinking of using an extension cable, connect it between the ignition battery and the ignition and cutting one of the three wires of the extension and connect the two ends to the two ends of the GP kill switch wire.
Whould that work? Which wire should I use? Any better suggestions?
Thank you all in advance
Serafim
