Hi David,
Can you let me know your set up? We might be able to help you if we know what receiver and channel allocation you are using.
A simple Pmix with channel 2 as Master and Channel 5 or 7 as slave should work fine, but you will want to remember to go into your Aux channel and null any switches or dials that 2nd Elevator servo is assigned to.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: bandit002
I have a new 7CAP and am attempting to setup dual elevators on a hanger nine showtime. Have attempted multiple pmixes using channel 2 and 5,(and 7), all to no avail. Only the channel 2 servo works. Have tried making ch2 master and 5,(and 7) slave, but the 2nd channel will not function. Is there any way around this that I am not aware of? Have been told there is a y harness with a built in reverse for the 2nd servo, but dont know much about them. (also have been told by one person that his failed in flight). Any help appreciated.
David
