RCU Forums - View Single Post - Engine Mount
Thread: Engine Mount
Old 03-20-2006 | 02:35 PM
Rod Bender's Avatar
Rod Bender
Default RE: Engine Mount
Ok, Time to beat the drum again. I'm done with all my trim monokote (Thank God), have completed the servo mounting in the wing for the ailerons, and am now ready to mount the engine. As suggested above, I went to install the engine (Its been on another plane until now) and the ply mounting is about 1/4" below what I need for clearance for the muffler, needle valve, and idle\throttle adjust. My options are A: Cut the engine side cowls for all 3 mentioned, or B/my thought: Raise the engine mount 1/4" to give the needed clearance for all 3 mentioned. Question is, by raising this for clearance, am I asking for trouble in performance or handling, or is this in a ballpark that’s doable? Some shots............ Thanks in advance, Greg
ID:	429817   Click image for larger version
ID:	429818   Click image for larger version
