RCU Forums - View Single Post - 2 wheel vs 4 wheel
Old 03-20-2006 | 05:03 PM
shamelessbill
Default RE: 2 wheel vs 4 wheel
I've been running mine as a 2wd since the first good wreck. You will burn up rear tires on the pavement.
You will also see an improvement in excelleration and top end. If your running street only its good. In the dirt you get no traction from all the torque in the ***** end.
You be the judge.
SB
