RE: 4-stroke on US 60
got a picture?
a couple thoughts
does it help turning the carb 180 degrees. cause it does flip over. also the set screw on the arm allows it to move around 180 degrees. Also a flex cable can make it around objects very well.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK055&P=0]flex cable[/link]
solder the clevis on one end and use a screw lock connector on the other [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK098&P=0]screw lock connector[/link]
