RCU Forums - View Single Post - ST2300 Testing and Experimenting
Old 03-21-2006 | 01:17 AM
  #300
Lomcevak-RCU
Default RE: My 2300 only likes one prop
Alright everyone I've got my 2300 running perfect after 4 LONG gallons of fuel. Here's my setup. Try it before you give up.
-OS F Plug
-Bisson Pitts with 1 tube blocked and then drilled out with 7/64 drill bit. (allows excessive oil and fuel to drain)
-Large fuel tubing on EVERYTHING including Large clunk
-Perry Non-Pump Carb (Allow for carb opening to only open 85%) THERE IS NO RPM GAIN AFTER THAT!!!! Just bad transition.
*this creates slightly larger diameter as OS 7D at full throttle*
-14 ounce fuel Tank = Solid 15 minute flight NOT including taxi and landing. (conventional tank setup)
*Tank Must be center with SPRAYBAR! NOT thrustline
-Mejzlik 18x6 (9000 rpm on 5% Omega) !!!!! Prop is For Sale !!!!! -- going to be using 19x6 Bolly ---
This Combo has finally gave me NO deadsticks, Idle at 2300, PERFECT 3D Transition, and Hey! how can you say no to 9K on 5%?
good Luck-
