Rcs 75cc
I forgot... If your engine won't start by hand with it's electronic ignition, something is wrong, either with your ignition or fuel system. I would suggest you check your carb adjustments closely. If you are very rich your engine will be very hard to start. Have someone in your area assist you with engine adjustments. Once set you shound't have to change anything for quite some time.
